Indy is infamous for their horrible valve jobs. I think most engine builders have learned by now that Indy ships heads complete just to save space. They don't intend the heads to be run out of the box, they assume that you'll take them apart and have them machined properly before putting them back together. Trick Flow heads come ready to run out of the box although it doesn't hurt to pull them apart and double check everything.
Andy,
Is this still true since the new owners took over?
Thanks,
Bill
