I've had a 76 Ramcharger and a 78 W150. Both trucks had factory 400 engines. They both had the dipstick tube run to the pan with the 90 degree fitting. Actually, every factory rear sump big block pan that I've seen, has that fitting. I'm not saying that that's always true, just what I've seen with 70's trucks engines I've worked with.
