Quote
The existing pickup had a lot of wear on the pickup (that sticks out beyond the coil) versus the new one out of the box.
Glad you got it fixed. My concern would be how did that wear occur? Might want to check your distributor shaft side play or vacuum advance plate slop if you're running one. beer
