CHECKING FOR SPARK
If triggering with the Magnetic Pickup:
1. Make sure the ignition switch is in the "Off" position.
2. Remove the coil wire from the distributor cap and set the terminal
approximately 1/2" from ground.
3. Disconnect the magnetic pickup wires from the distributor.
4. Turn the ignition to the On position. Do not crank the engine.
5. With a small jumper wire, short the magnetic pickup Green and Violet
wires together several times. Each time you break this short, a spark
should jump from the coil wire to ground (the LED should also blink). If
spark is present, the ignition is working properly. If there is no spark skip
to step 6.
6. If there is no spark:
A. Inspect all of the wiring.
B. Substitute another coil and repeat the test. If there is now spark, the coil is at fault.
C. If there is still no spark, check to make sure there is 12 volts on the small Red wire from the Street Fire Ignition
when the key is in the On position. If 12 volts is not present, find another switched 12 volt source and repeat
the test.
D. If, after following the test procedures and inspecting all of the wiring, there is still no spark, the Street Fire
Ignition is in need of repair. See the Warranty and Service section for information.
