Originally Posted by kentj340
There is a blog titled "MOTOR OIL ENGINEERING TEST DATA" here by a mechanical engineer wherein he tests over 250 different oils and discusses many topics.
One article is "Here is what you should follow for a successful start-up of a new rebuild of a traditional pushrod flat tappet engine.:"
Another is "STD VOLUME OIL PUMPS VS HIGH VOLUME OIL PUMPS – IS THERE REALLY A HP DIFFERENCE?"
He uses a gear oil test to test engine oil. Not a good way to test an engine oil. That guy has been kicked off many web sites for posting crapola.
Just because you think it won't make it true. Horsepower is KING. To dispute this is stupid. C. Alston
