Originally Posted by usp4u
Originally Posted by Wirenut
Originally Posted by Cab_Burge
Nitrogen molicules are bigger than O2 molicules and won't loose pressure like O2 does, especially when sitting up
they don't expand with heat or shrink with cold either up scope
Correct and that’s while circle trackers use it.
Don’t know if it would benefit us
Not really. Dont forget the regular atmosphere you are currently pumping in your tires is already 78% nitrogen, 21% oxygen, 1% various other gases
I have yet to see anyone try to collapse a tire to get all the air out before filling with nitrogen so it is still a mix
1969 Hemi Roadrunner 2nd owner
