I am in the long process of relocating to just outside of Concord, North Carolina, and looking to put up a 40’ X 60’ metal building. Can anyone give me recommendations on a good contractor that is trustworthy and fairly reasonable? I will definitely check references and take a look at a few previous installs. I will also check out with the BBB. Looking for experiences with putting one up and what to avoid and look out for. I have a recommendation for a concrete guy from a good source, but not sure if it is beneficial to have the contractor handle the whole thing so that there is less chances of a disconnect or misunderstanding.
One thing i heard is to have the pad exactly the size of the bldg so that the sides tuck down along the slab sides for no leaks. Really looking for contractor that you had a goid/great experience with, because i’d rather not pick them off the web.
Thank you.
