Looks about right. The 512 low deck in my Duster made 603 @ 5900 with ported Mopar 452 aluminum heads and a 246@50 hyd roller cam. I used a Trick Flow intake rather than the Torker but everything else is pretty close to what you have there. Mine idles at 950 rpm with 16 inches of vacuum but pulls hard in every gear.
