You sure it's not ignition related? I'd be swapping out coil or ignition box before I pulled a valve spring unless you find broken ones (could be product of valve float). ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) I'd rule out the ignition system first. ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) I also agree that those spring pressures seem light for a heavy hemi valvetrain.
