I got the splined part welded to a big body washer and drilled holed to mount on the 3 factory holes.The center shaft has 1/2" 20 thread like a lug nut so I used a shanked lug nut and cut it short to fit the center length needed and trimmed the acorn on top to fit under the steering wheel.
GOTBOOST!New improved with Victor heads.
http://www.enginelabs.com/mopar-big-bloc...t-of-necessity/
