It depends on how you actually are going to use it. You have full time 4WD so making a low rider make no scene(to me anyway). I think just fixing it up to be a nice rider would be best. 4X4 drag truck? Are you talking on asphalt or dirt? Either way mods will need to be done so get another truck that you can cut up and make it into either one. Take a bit from each, Mod it (lift kit, bigger tires, different motor etc) I would like to drive it because when was the last time you seen one of these on the street?
