I did end up putting a gear drive in it. Not that I had any issue with the chain/tensioner. I figured it was going to be a problem, so I ordered the gear drive after the motor was together. I probably should have done it in the first place. Project creep turned this motor into a lot more than originally planned.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
I don't regret the things I've done. I only regret the things I didn't do.
"Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
