Geez, Wally that thing looks killer!
Love the 904, I'll go against the grain here on the "more convertor" suggestions and say with 420 inches, a 4:30 rear end, and low first gear you need
less convertor to hook up.
Keeping the convertor you have, maybe consider 3.91's to keep that stroker rpm down at the big end and help from blowing the tires off at the start. I have to apologize, I have a bitter dislike for steep gears, mainly because modern Factory hot rods are running some unbelievable times with mid 3 rear end ratios.
I'm going to say 11.20 with traction issues and 10.80's in a perfect run.
Get it finished!
