Anyone attempted using a mule block set up for cam break in?
Is anyone offering this type of service?
Thinking of setting up an electric motor with a rheostat to spin the cam, plum the block with external electric pump to oil the cam journals, spray bar for the lobes, and run lines to the rocker arm shafts.
Interested in you guys thoughts on this.
