There is no heat crossover passage on the RPM heads, so you can remove that whole thing off the bottom of the manifold without any problems as a result.
If this is for your stroker, there is likely some power to be gained by using a “better” manifold.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
