cudaman1969, both cars have headers. Both cars were street driven into the track, raced, and street driven home. We did not uncork. Both cars are running drag radials. Honestly, the only difference that I see is traction. In fact after one of my runs in my automatic car with a huge bog when I got to the return road I stopped and brought it off and it was perfect; literally 20 seconds after the bog on the line.
Well that tells the story, blowing the tires off shows the problems, timing and carb. Ump timing up to full in (37) by 2000, tighten the air door a turn or two.
This.
Age old problem back in the day with the factory AVS. Car's fine on the street. Sticky tire/hot track - bog. Tighten the air valve.
