You bet, I kind of ran into that with that Neon: Someone else had tried to repair it, they cracked the top plastic retaining ring and Fubar'd it up with gasket in a tube. It was leaking gas through the ring which is all the problem really was, but, when you have it all apart anyway..................
Getting the whole pump and assembly was only $40 more, so I just bought it for Her so She would never have to worry about it again.
Make sure you clean your fuel tank out real good: Your truck will go forever if you do it now.
Rock uses that heart symbol on their best selling products, I seen one on there looking at pumps: I'd pick that one, but, that's just Me.
