When I took mine off I had a similar problem on the drivers side. As I am doing a complete rebuild, I loosened the LCA all the way and finally just took an angle grinder and cut the stupid bar. I was positive there was no pressure on the bar and their wasn't, but I sure was nervous as all heck while doing it. Finally, I beat the bars out from the back as even with cutting them and pulling the one end out the front, the back would just not budge.
67 Barracuda FB
69 Superbee
"Southern Maryland: If you want a good looking woman, you had better bring her with you"
