This is the intake I built for the TT440. I plan on dropping it on the 541 but don't want to mess with the old Electromitive TEC II system I ran back then. The 120 lb/hr injectors need to go and I'll have to build a sequential harness for it instead of the paired injector arrangement I used.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind.
- Stu Harmon
