I really don't know what size the carb is, as it is a bit of Frankenstein. It is basically an 850 Brawler with a Quick Fuel 950 annular main body and some older Holley 2 emulsion hole metering blocks. On the list it is C4. In my testing last year C3 seemed to work best with the RPM and 2" 4 hole spacer. but I hadn't run the 850 version with the RPM intake and 2" spacer, so that is what I used for my first test and tune. It's not pulling the front tires any more but the 60ft was better.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
