I watched the video and I like the idea of putting the small tube in first (behind the light), even though no one has done it. I think it would be easier too, if you trim down that tube on the side it goes into the air box. It looks like a good 1/2" of plastic could be removed on that outside of the tabs. That would give quite a bit more room to install it.
I think there’s several brands of these two parts, and there is likely some small tolerance variances.
The one’s coming to me are Mopar OEM, so I’m hoping for no issues.
