Had this same problem in my RoadRunner many years ago. Finally traced it to play in the (original) steering box. Not the usual play that you can correct with the adjustment screw on top. The needle bearings on the sector shaft had worn/rusted a small amount allowing the shaft to move - very hard to diagnose. This started without out any warning during a 3 day weekend at beaver springs.
