Originally Posted by topside
Are the tires bouncing up/down r shaking side/side ?
How much caster are you running ?
Some high-caster setups will wiggle the tires side/side, fairly common on Sprint cars.
Genrerally on decelleration, and in a window of speed, say maybe 60-45 MPH.
Went from 2 to 4 degrees. Observers in the other lane noted the tires are bouncing up and down, but can't confirm this. Steering wheel shakes when this happens.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
