Originally Posted by I_bleed_MOPAR
Trailer sway without a doubt. I towed an '01 Dakota ClubCab 4x4 home from NC behind my '06 2500 on a UHaul trailer. I wound up using backroads to get back as when I hit 55 it would start to sway.
Tim
So, just curious - what are the loading strategies to avoid sway? Is the goal to have the load balanced on the trailer so the hitch isn't loaded much, or is *some* load on the hitch better to plant the rear tires? ..maybe there are different solutions to different situations?
I've towed a few things in my lifetime, and I know what sway can feel like. But my loads and the trailers I used were fairly "ordinary" - construction site office trailers, boats, building materials, etc.
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
