Originally Posted by mopowers
Thanks! Does that mean you can't use the pre-74 input shaft with a 74-up support?
You can if you drill the hole in the support; I use a long #40 bit. I've seen these parts mismatched and it doesn't seem to cause any harm; the factory is a little conservative when it comes to parts interchange.
The INTERNET, the MISinformation superhighway
