Originally Posted by John_Kunkel
The casting number didn't change over the years, the machining is what makes the difference. Easiest way to spot the '74-later support is the absence of the front clutch lube hole. (see pic)
BTW, the rear clutch piston is wrong for the Belleville, the later Belleville needs a thicker piston with the casting number 3743623.
What is the hole on the input shaft with the red arrow for?
