I'm assuming 2.66 1st gear 833. At least the 4.10 probably could run a 4.56. If street driven Cal Tracks. Good shocks, bias slicks. The clutch better have some slip. If not the 833 may not have a long life span for track use. If it was an auto 3.91-4.10 Doug
I believe the 1st gear is 2.47 or similar. I don’t know what clutch to run yet. That will be one of my next questions.
