I am almost finished with my 511” stroker and need to start thinking about the back end of the car.
It’s street strip and I know I’ll get a few different opinions on this. Combo is
511
11.6 comp.
TF 270 heads
Indy sp ported 1050/4150
2 to 2 1/8 header
265/268 .660 on 108 solid roller.
4 speed
It’s a Cuda. I plan a 1” spring relocate and a 9”. I want a 29.5 or 30” tire.
I don’t know what leaf springs and cal trac? My thoughts are a 3.73/3.91/4.10
Gear. I’m thinking it should trap around 130?!
What would you go with for suspension and gear?
Do you have the rear yet? If not you might be interested in the S60 that I'm pulling out of my Duster. I'm going to sell the S60 plus the wheels and tires. It might slide right under your car. It has 4.10 gears and a Detroit Locker along with disc brakes.
