Originally Posted by A39Coronet
My concern with the OE design is, if something were to occur with the battery and all 95 amps head through the bulkhead connector to the ammeter, I can't imagine things would end well. Unless I'm mistaken on how the OE meter would respond.
If you look at the stock ammeter in a '68-'70 Charger, high scale is 40 amperes. So if you ran 95 amps through it, the needle would be pegged to the right. Fortunately ammeters are pretty rugged and I doubt if the gauge would be damaged but the stock wiring harness at 95 amps? That probably won't turn out well.
"We live in a time when intelligent people are being silenced so that stupid people won't be offended".
