Years ago member 340SIX(?) posted a picture of a small hole drilled on the back side of the hubcap that was out of view when installed. You were supposed to stick a small hook tool into the hole and use it to tug the hubcap off. I think it would work fine on a stainless cap, but not sure how an aluminum cap would hold up depending on how much force was required to pull it loose.
