I just finished mine yesterday, started with a rusty oil pressure gauge, removed the faceplate, cleaned it up with muratic acid. I then drilled to match the new autometer volt meter faceplate with some trimming, painted, installed the decal and screwed it together. The hardest part was aligning the 2 faceplates to get it to drill on center and vertical. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
I didn't do 4 years and 9 months of Graduate School to be called Mister!
