Originally Posted by ek3
you wiped lobes ?? or lifters ?
The nose on every lobe, it was a long discussion on here, the lash never changed
1968 Charger COLD A/C Hilborn EFI
512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim
2020 T/A 392 Stock 11.79 @ 114.5
