If you’re referring to the cam in my pic...... it doesn’t look good in the pic, but that lobe is perfectly fine.
As are all the others.
The brighter area on the left is untouched by the lifter.
The lift on both sides of the lobe is within .001”.
The color of the cam and lack of parkerizing should be a dead giveaway as to where it came from.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
