I'm not aware of any reproduction of the "plug-in" OEM Hurst shifter.
I have, though, drilled a stock lever for the bolt-in style Comp+ shifter and it works fine.
For the OEM version, as far as I know they're rebuildable, if you're OK with tying the car up for that.
