Just how big an alternator do you need to run an aftermarket EFI? 90 amps seems serious overkill.
It's not for the EFI alone it's for
Holley kit Stealth Super Sniper, Fuel pump A1000, Regulator Bypass regulator, MSD Pro Billet Distributor, MSD 6AL box, headlights, electric water pump, Contour fans set up, stereo (not currently a need but I want the option of it) and charging the battery
