I think you're all missing the point of a 440Source head ... they are made to be a direct replacement for a standard cast iron head. So compare apples to apples. As they come from 440Source is probably as good as any iron head out of the factory. If you're going to have heads checked, machined, ported, polished, blueprinted and flowed then you probably shouldn't be starting with 440Source heads !!
Disagree, dollar for dollar the 440 source heads win just because of the weight first and foremost. Then ease of porting. And deck mill. But if you just slap em on, still 9/10 better than a factory iron head
