Anyone have any experience with using a Trick flow or any other unit with a cam thrust button and Indy cast alum. timing cover for solid roller applicaton. Cab has recommended comp cams #7125 and it looks really good on the face of the cam gear from the photos. Looks like more room to accomodate a thrust button and bolts. Thanks, Bill
