You bet, I did read about clearance issues with the stock 4x4 tires.
I went with 55 series 275's and it all clears. It took forever for 55's in the style of wheel I wanted to come up. These are a Dodge rim with Ford Pirelli tires and the balance is spot on. The lower profile looks a lot better on a 2wd.
Now, I'm thinking of lowering it: maybe cut 3/4 ton coils for the front and just remove the overload bar in the back should do it.
