I've installed nothing but Poly/delrin/nylon bushing in my toys/DD or customer's vehicles for the last 3+ decades, and learned the hard way to avoid squeaks, don't tighten components until at ride height, use the mfg recommended lubrication, never use petroleum based lubricant during install or usage, follow the mfg's recommendations if your not sure of install procedure...
Mike
