Originally Posted by DrCharles
Originally Posted by TJP
Not exactly sure of the problem area but having the OD of the socket turned down would be a quick and dirty approach. or possibly even making a "special" socket might be another approach. Can you post a few pic's ?? beer
It'd be next to impossible to get a pic of that area... maybe through the hole in the fender if I took the wheel off! scope
But the description should cover it - the OD of the socket is too big and it hits the header tube, preventing it from going on fully and straight...
On FABO someone suggested these: https://www.summitracing.com/parts/pow-pow301155
But $68 for two sockets! Although it looks like it would do the job whistling
I think I'll try a friend with a lathe first smile
If you don't want to pay $68 for two sockets then you don't want to buy a single socket from Snap On either. laugh2
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion.
2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
