I was talk into buying a new set of the Speed Master(AKA Pro Form) BB Eddy Victor clone heads (part # PCE281.2142) with CNC porting with 325 CC intake ports.
I ASSUMED they would be M.W. intake port size, not so
The intake ports are way wider in the pushrod pinch area than any stock Mopar heads I've seen
and they have 2.200 intake valves along with 1.81 exhaust valves with soft CNC combustion chambers
My question is are any of you on here using them? If so what are your thoughts on them
Thanks in advance on ALL comments
