I am curious how much my factory exhaust manifolds might be holding my 1976 360 back.
Here are the specs:
- Stock bottom mid-70's 360
- Factory 2bbl was rated at 180hp @ 4,000 and 290ftlb @ 2400
- Milled [63cc] 2.02 J-heads, somewhere around 9.3:1 compression ratio
- Edelbrock Performer RPM intake
- Comp Hyd Flat Tappet, 0.470" intake lift, 0.480" exhaust lift @ 270/280 duration
- Comp 901 matching valve springs
- Stock rockers
- Holley Sniper EFI
- Stock exhaust manifolds with factory 2>1 single exhaust (2-1/4")
The truck runs decently well up to about 5,300rpm and it starts to fall off quickly thereafter. The cam and intake should pull pretty well up to 5,800, but I have a feeling my manifolds disagree.
I am not looking for a race truck, just something that is fun to cruise around in,
how much are those factory exhaust manifolds holding me back at the top end?
