Originally Posted by NITROUSN
Could be the relay. That's the easiest and cheapest item to try. Low voltage can cause odd problems and contact fusing. Was it cranking normal or slow?
Probably the back up light switch. I've had it happen several times, LOL Just stirthepot
I'm with Nitrousn on this one wink
