Passon can sell you a 100% stock 4-sp install kit with his overdrive gearset for the 833. This means stock mechanical clutch linkage, stock appearing trans, etc. The gear ratios in his 833 w/ overdrive gearset are pretty much the same ratios as a 727 but with a .8:1 4th gear.
