Originally Posted by Moe
On another message board a member writes"A lot of engine builders will not run the fluidampr, they say they can crack a crank"
Is this true......or BS??
True, as in every dampner can break a crank under the right conditions. So the real question should be, is the fluidampner you have chosen the right/best solution for your application.
It is a "BS" statement you have shared from the other board in that it omits a lot of important details.
Reality check, that half the population is smarter then 50% of the people and it's a constantly contested fact.
