Originally Posted by RSI700VIPER
Originally Posted by NANKET
The trim ring has this step that hits the rim edge and stops it from going on. So hitting more will just damage the ring
Measure this distance on an original and compare to your Reproduction rings. mopar performance part numbers start with The letter P.
NOS Chrysler part numbers do not.
NANKET - Are you sure that the problem? I think I'm well past that on the step in the rim. Is there a simple Mod to get them to seat? Maybe cut a relief slot?
Take some modeling clay and make some strings of it, place on the wheel from bead area down towards the web. Install the trim ring and remove it, see where the clay gets cut.
