Hi guys it’s been awhile since I last posted but I have a question
I have a bone stock 69 440 that I want to put a comp cam in
And I wanted to know if you think it will fit with out hitting valves to pistons
The cam is 545 lift with 285 297 duration
The pistons are .034 down in the hole.
And fel pro gaskets
I will be running stock Eddy rpm heads.
What do you think can I run this cam in a stock
440
Thanks in advance.
I am going to say no but the LSA could be wide enough at about 14.you can check easy by pushing on the valve and measure the stop distance.
