We had a great day today. I went to another teams dyno to test. I'm lucky to be able to do that just to compare there power to mine and we killed it. We were a tiny bit down at 9000 but from 9200 and up we have power to run with the best. I think the problem at 9000 is valve spring issue im pretty sure I can fix that with a .030 shim. Its funny when ever you got something going on around 9000 it always seems to be valve springs.
