I have done both, seen both. If you are having trouble I personally have never seen going directly to the battery fixing it. It was always a faulty component. So necessary ....imo no. Just make sure you use sound wiring techniques.Good chassis/engine ground, use the the heavy wire coming from the battery for your pick-up point. If you want to get technical, check your voltage drop/ resistance to ground at different points.
