Originally Posted by krautrock
i think the Ross 99496 might be the only piston for the 3.91"/6.76" combo in a low deck. the piston has 3.5cc dish and uses oil ring support rails.
I'd love to hear if anyone has experience with them.
I did a build back around 2003.
It worked well and had no problems. I went to a 4.25" stroke setup a few years later.
471 CID, 4.375 bore x 3.915 stroke, 400 bore +0.033, 440 crank
400 block, pad stamped 5T400, 6 12 E. Side stamped 5G202367
Casting 4006530-400-10, 2-15-75
Forged steel crank from 440 (small thrust surface)
Ross Pistons 99496, comp height 1.238, listed for 3.915 stroke, 6.768 rods
measured compression height 1.242" (extra 0.004" on top of piston)
Manley Sportsmaster I-beam rods, #14279, length 6.765, BB Chevy journal, .990 pin
measured length 7.758"
Scott Brown custom solid lifter cam, 272/280@0.050", 0.622"/0.600" lift.
Installed 4 degrees advanced.
Block decked to 9.962" (spec 9.980")
1993 Daytona, 5.50 at 130mph (1/8) 1.19 sixty ft (PG). Link to 572 B1 - Part 1
